Results 1 to 19 of 19
    Sep 2011
    Raleigh, NC
    Meth options on a Cobb
    Hey guys!
    Ok, I swore I would not do meth. But, well, ya.. we know how that all goes. You can see my mods below but meth seems to be the last "easy" way to add power. Unfortunately I cannot get alot of information regarding how it ties into your car if you do NOT have a JB.
    So, my question is are there any good meth delivery systems that are standalone? Do they have a failsafe that will cut boost/throttle/whatever if the meth flow fails?
    I *think* i've heard Cobb discussing meth maps but, either way, I should still get a decent boost simply by lowering the IAT's. Is that an accurate statement?
    2008 BMW 535iA | Cobb Stg2+ | FBO | Meth
    NYC
    104 Post(s)
    Hfs-3. Although a basic meth kit will do the job just fine as well.
    45 Post(s)
    There is currently no meth integration directly from Cobb. Themyst is working on a boost solenoid bypass with meth on Cobb. Havent heard him post about his findings. Only way right now is Cobb with JB4 To control the meth fail safe.
    Chicago Burbs
    21 Post(s)
    I asked Rob at Cobb what to buy that he felt would ultimately match best with the cobb tune. He said to hold off on buy a kit until they determine how they will intergrate. This was over a month ago, but I plan on sitting out the winter and hope they have something come next spring. That or I am going to buy a 911 turbo.
    Sep 2011
    Raleigh, NC
    Thanks guys! Will probably wait for spring as I don't really need it right now. Hopefully Cobb will have an integrated solution by then.
    25 Post(s)
    Whats wrong with a standalone meth controller or simple boost sensing switch?
    Some people live long, meaningful lives.
    NYC
    104 Post(s)
    Click here to enlarge Originally Posted by DBFIU Click here to enlarge
    Nothing. I'm running a bare bones basic meth kit with pressure switch activated at 9 psi and it works just fine. Now if I could only figure out this timing flatline issue!
    Just verified it flatlines on pump gas now too so I don't been believe it's meth related and could have simply been a odd coincidence. Car pulls plenty hard even with the funky timing though.
    Sep 2011
    Raleigh, NC
    Nothing really. The aquamist system looks nice but I don't want to hack up the interior to put a gauge in. I'm "hoping" that cobb may be able to integrate it into their tune so I can get some data on it. I've been really against meth as it's still somewhat a family car, I may just pull the trigger but it's been difficult to get "good" information (at least for me) to find out what meth systems are dependable and work as a standalone device.
    I'd rather not have meth flowing all the time and I don't want to risk the engine if my meth runs dry. Without integrating it into a tune I also won't the full effect so, in short, I can just wait around for a bit (i'm not in a hurry) and see what develops. With my FMIC, my intake temps are generally running about 15 degrees above ambient when cruising and will drop to about 10 degrees above ambient when I got WOT (for a short time then it starts climbing).
    25 Post(s)
    Meth doesnt flow all the time. You set the threshold by which it starts to flow. You can set it to 11 psi if you want. Right now I have just a simple boost sensing switch. No need for that mumbo jumbo controller garbage. Really simple switch and meth line is all it took.
    Sep 2011
    Raleigh, NC
    Thank you! I guess the question really is, if the tune is not aware of, or taking advantage of the meth, what advantage will I really see?
    NYC
    104 Post(s)
    Click here to enlarge Originally Posted by xclone Click here to enlarge
    cooler charge air temps, lower fuel trims, but performance-wise, next to nothing in the real world.
    25 Post(s)
    It will allow you to run more boost and make more power.
    Sep 2011
    Raleigh, NC
    Of course but Cobb doesn't currently have any meth maps so, in short, it won't add any HP, just lower IAT's (which I don't really need in the winter), right?
    NYC
    104 Post(s)
    A public race map is inevitable. Get a meth kit when that time comes.
    Sep 2011
    Raleigh, NC
    Click here to enlarge Originally Posted by themyst Click here to enlarge
    Thanks Myst! Any recommendations on what type I should look at? Or would it be best to wait for the meth maps to come out and see if Cobb gets a hardware solution in place?
    NYC
    104 Post(s)
    IMO, doesn't really matter. If you want the best, spring for the HFS-3. If you want something simply for race day, a basic kit and failsafe will be fine.
    Click here to enlarge Originally Posted by Cn555ic Click here to enlarge
    So meth with a Cobb essentially requires a JB4 to manage it?
    Click here to enlarge Originally Posted by mithiral67 Click here to enlarge
    Doesn't make sense for you to sit around waiting forever.
    Chicago Burbs
    21 Post(s)
    Meh, its to cold for more power. I already have traction issues.
