Results 1 to 6 of 6
Thread: oil change reset
05-01-2011, 09:27 AM #1
oil change reset
hey guys i looked around but cant seem to find how you reset your oil change counter.. any input?
JB4LIFE
05-01-2011, 01:38 PM #2
Start engine.
Hold day milage counter reset button for 25 seconds.
DoneThere are two theories to arguing with women. Neither one works
05-01-2011, 03:49 PM #3
05-01-2011, 03:58 PM #4
Hmm that's different than what I have saved here. I haven't used it yet as I'm still just under the warranty period, but here's what I have
How to reset maintanence codes:
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
05-03-2011, 01:43 AM #5
- Strong Island
- 3,432
- 3,063.0
- 101 Post(s)
- 31
05-03-2011, 01:47 AM #6
