Results 1 to 17 of 17
Thread: OVERBOOST HELP
03-27-2011, 11:34 PM #1Member
- Oct 2010
- 287
- 93.5
OVERBOOST HELP
At high boost getting an overboost, car hesitates until it goes into limp mode , I'm pretty sure it's a vacuum leak, checked both bov and stock diverter valves looks OK to me, but happens with both sometime after 11 psi , is there anyway to do a vacuum leak test in the shop ? besides just looking at the hoses ? Maybe it's my wastegate actuators ? How can I check ? This drives me $#@!ing crazy !!!!! :mad0259::confused2 tried IT WITH NEW OLD AND EVEN OLDER MAPS so I doubt the tune is causing it
03-27-2011, 11:47 PM #2Timeout
- NJ
- 13,412
- 58.0
- 318 Post(s)
03-28-2011, 12:28 AM #3Member
- Oct 2010
- 287
- 93.5
fmic, dps, mufflers, cp-bov , intakes , meth - tank is off ( for the past 6 months ) , occ, procede , cp - bov was the last thing I did , thought it was the problem, took it off and put stock cp with dv's and same thing , I'm thinkng maybe the O ring needs to be changed on the throttle body connections ?
03-28-2011, 03:04 AM #4
bump for help
03-28-2011, 03:33 AM #5Member
- Stockholm
- 1,527
- 1,185.7
- 61 Post(s)
you need to do leak test . What settings are you running ? try to post a screen shot of the user adjustable parameters and the codes you are getting.
03-28-2011, 08:02 PM #6Timeout
- NJ
- 13,412
- 58.0
- 318 Post(s)
are you sure you connected everything properly? snap some pics just be sure of the easy stuff
04-05-2011, 11:44 PM #7Member
- Oct 2010
- 287
- 93.5
04-06-2011, 12:33 AM #8
04-06-2011, 12:35 AM #9Timeout
- NJ
- 13,412
- 58.0
- 318 Post(s)
04-06-2011, 01:32 AM #10Member
- Strong Island
- 3,432
- 3,063.0
- 101 Post(s)
- 31
If you had a vacuum leak you would be getting under boost codes for failure to achieve target. Over boost codes I would remove the tune and drive it...you might have a stuck closed waste gate.
04-06-2011, 02:36 AM #11Timeout
- NJ
- 13,412
- 58.0
- 318 Post(s)
if on JB4 and overboost, he may have FF max set too high..? maybe? i dunno.. do what Matt says
04-06-2011, 03:40 AM #12
04-06-2011, 03:41 AM #13Timeout
- NJ
- 13,412
- 58.0
- 318 Post(s)
04-06-2011, 12:03 PM #14Member
- Oct 2010
- 287
- 93.5
It was the wastegate, but I might of had 2 problems, wastegates and the boost leak, because since I've removed the procede I got the under boost code, could that code be for wastegates as well ? if let's say they open and don't close all the way or something ? or boost leak only can cause that code ? Thanks ( I've reused the same o-ring like 5 times on the charge pipe so I've ordered a new one from BMW just in case, DIC maps on procede were causing the problem with my wastegates, however on the previous maps it didn't happen, but I might of abused my wastegates that I need new ones now IDK !!!
04-06-2011, 01:01 PM #15Member
- Stockholm
- 1,527
- 1,185.7
- 61 Post(s)
04-06-2011, 11:18 PM #16Member
- Oct 2010
- 287
- 93.5
04-07-2011, 12:10 AM #17
Is there a check valve on your meth kit? Is the line still connected might be leaking from there
JB4LIFE
