Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    Nov 2017
    How dangerous is it to run aftermarket turbos (RB next gens) with just an OTS tune? (MHD)
    Im aiming to have new turbos fitted for me at a shop in southern california.
    Prob is that I live ~500 miles away meaning ill have to drive the untuned car from the shop back home (im going to stay in so cal for the week too which = even more city miles)
    Ill keep the car as low in the RPM range as possible, but will prob cruse ~75-85mph on the way back
    How big of a problem will this be if I only have the MHD OTS maps?
    Could I leave on stage 2+ and drive without worries? Should I instead set to stage 0?
    Ill get a custom tune as soon as I return home and have familiar areas to data log/test the base maps)
    With a JB4 not a huge deal, it will mostly compensate on it's own. With a flash only map just don't go more than half throttle and should be OK to putt around.
    Nov 2017
    Gotcha - so youre saying it's not RPM sensitive as much as throttle dependent? Its a 6spd so ill try to keep it which ever gear allows the least throttle whilst in the city
    Also, can anyone explain the exact issue with running untuned equipment?
    In my head im picturing the ECU seeing too low PSI at low RPMs (larger turbo takes longer to spool), and it trying to compensate with duty cycle, only then to have it overboost when the RPMs pickup and cause engine damage? (air, fuel, and timing cannot adjust enough)
    Is this thought process even in the ballpark?
    Jul 2012
    Boston, MA
    90 Post(s)
    Contact your tuner of choice, I vote @motiv.
    They will give you a basemap you can load when you pick your car up. Then log and flash from there.
    As you need a custom tune might as well start on a basemap and have it from the get go.
    As stated above don't go above mid/part throttle and you should be fine. But get the basemap and start tuning from day 1.
    Oct 2017
    11 Post(s)
    some one as talented as motiv needs to be in Aust!
    Jul 2012
    Boston, MA
    90 Post(s)
    Click here to enlarge Originally Posted by evl335 Click here to enlarge
    They do a good job remote tuning FWIW. You can always set up a dyno tune session with them if you want to get it done all at once. Just make sure maintenance is done.
    Oct 2017
    11 Post(s)
    really thanks for the heads up ill look into it
    If you are looking for a quality tuner in Australia @JD75 or @martymil can help you out.
    Sep 2015
    Down Under
    32 Post(s)
    I dont tune peoples cars, liability reasons.
    Choose any of the remote tuners like @motiv or the like
    Nov 2017
    Click here to enlarge Originally Posted by Torgus Click here to enlarge
    This is a really good idea, thank you!
    Nov 2017
    Ive researched the forums and it appears there are quite a few tuners but not all are taking business.
    From what I found:
    V8Bait (forum member) - Rated as best of the best, but doesnt appear to be taking new business
    Motiv - highly regarded by posters, but quite a few complaints that it takes months to actually get anything done (revisions and comms are super slow)
    Twisted Tuning - a lot of positive feedback around quality and communication - (this seems my best bet so far and I emailed them)
    BQ Tuning - limited info/reviews. Facebook only?
    Trebila - doesnt appear to taking new business
    Wedge - strange mix of happy and unhappy customers. Seems he created the OTS MHD maps?
    Pureboost.de - Worried about language barriers since site is 100% german. €399 price tag...
    PD Tuning - cant find many reviews but he has a "lifetime" of free tunes? Site says base tunes are sent out in 1-3 days. Very interesting.
    Let me know if there are any forum favorites I should try.
    Im aiming to get the hardware installed Oct the week of the 14th
    Details around the vehicle:
    hardware: IJE0S
    2008 535i 6spd
    ~65k miles
    Running MHD OTS stage 2
    To be installed:
    RB Next Gen turbos (15t compressor / 11 blade wheel)
    RB Inlets 1.75"
    VRSP catless downpipes
    PSP 600ic intercooler
    ER charge pipe
    turbosmart diverter valves (set to recirculate)
    Less than 15k miles:
    NGK 95770 gapped to .022
    Delphi ignition coils x6
    Version 12 BMW injectors x6
    Walnut blasted
    pierburg boost solenoids x2
    waterpump and thermostat
    Edit: most importantly, this must be a tune for 100% ACN 91 octane!
    May 2016
    44 Post(s)
    Regarding BQ; I've worked with BQ on my personal car for both my pump gas and ethanol tunes. The tune was solid, smooth, and most importantly (for me), BQ did the specific things/targets I asked for. This was especially important to me on my pump gas map using lousy ACN91 and ridiculous AZ temperatures. A guy that actually listens to your goals is worth a lot IMO.
    Jul 2012
    Boston, MA
    90 Post(s)
    Jake at motiv gets back to me within 3 business days usually FWIW. Go with the one you feel the most comfortable with.
    I noticed your list is missing EMP?
    Click here to enlarge Originally Posted by theobjectivist Click here to enlarge
    Just wanted to add, these tuners are on the forum:
    @TwistedTuning
    Also @[email protected]
    Also @kbaldi29
    Also @Dan@BPC
    Also @Tony@Codewerx
    Dec 2016
    15 Post(s)
    LOL Isn't going with the one that makes you feel the most comfortable how people started using EMP?
    Dean Fuhriman with RFPTuning and David Shoup have had some good results and are pretty responsive as well. Another thing to ask - are the tunes locked? I know most people don't care about that, and some will say it allows you to steal their work, but it just bothers me because you are now locked to that tuner, and only THEY can make any changes. I'll be redoing my own tune so I can modify it. Nothing is more frustrating than waiting a week or three to get a degree or two of timing added. Make sure you ask what the time limit is on the tuning. A lot are now saying "1 year of tuning" which I disagree with. If you can't get a reply for a week or two at a time, there should be no limit to the timeframe. I can understand changes, i.e. upgraded turbos, different intercooler, PI, etc, but not just for the initial tune.
    What shop are you going with anyway?
    Nov 2017
    It's called SSR Performance out of Orange, CA. They have good reviews on the 3 series forums and quoted me a reasonable price.
    The guy I spoke with mentioned they've installed "hundreds" of Pure turbos and that they can work on E60s too so Im hoping for the best.
    What's funny is that bmw shops in norcal (near sacramento) are incredibly sparse. I called six and none of them were willing to do any work if it involved downpipes, and even with OEM cats, they wanted 2-3.5x the price. I emailed two others in Socal, and none got back to me. Dunno whats thats about
    Im open to any recommendations with positive experience and in CA.
    I've heard of them and follow their social media posts. I think you made a good choice.
    Let us know how it goes.
    Jun 2016
    5 Post(s)
    Pureboost here, they're fluent in English and get good results...
    Ignore my sig, that figure is out of date
    335I xxxwhp, Chinesium FCBO. AliExpress 19t turbos. JE forged pistons, FCP engineering forged rods, king sv bearings, Vargas spline lock crank hub built block. 2x DO12 charge pipe 6x port meth injection. Stock charge pipe.
    Jul 2012
    9 Post(s)
    I've also looked around a little in the Sacramento area and concluded that it made more sense to drive or trailer it down to VTT in Hayward if I wanted to get turbos installed. I looked at shipping but the cost was ridiculous to go that short of a distance.
    Nov 2017
    quick update:
    From what ive researched, it's difficult to go wrong with Twisted Tuning or Motiv
    I emailed TT 9/26 and received a reply back 10/4 indicating a base tune wouldnt be a problem. (I also received a reply from Motiv but it came after, so I went with TT)
    I paid on 10/4 and TT sent me the base tune 10/10.
    I made an appointment for the install with SSR performance 10/29. It'll be the second time in my 20 years of car history/wrenching that someone else is doing the work. Feels weird
    Nov 2017
    Click here to enlarge Originally Posted by Carl Morris Click here to enlarge
    Agreed. Nor cal is not the best for these. You cant swing a dead cat without hitting a ford/GM/honda speedshop, but nothing for BMW.
    It's worth noting that I found a shop called N54 Exclusive Garage though.
    From what I read, they have two locations, (or maybe they rent two locations and you meet them at whatever spot is avail) Theres one in campbell/north bay. definitely weird, but they were nearly 1/2 the price I saw at VTT
  23. #23
    Interesting. The shop limits itself to just N54? Huh. Weird we've never heard of them.
  24. #24
    Jul 2012
    Boston, MA
    90 Post(s)
    They are probably to busy replacing parts on N54s to have a forum presence.
  25. #25
    Or trying to figure out what the latest code to pop up means...
