Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: JB4 NA Map Log
    25 Post(s)
    So thats what an N52 is like.
    Some people live long, meaningful lives.
    Mar 2011
    I love this..
    So Terry if i have cobb flashed and Jb4 installed too, can i use this NA map8 for valet, wife or even myself and then switch to map 0 on the fly to use the cobb tune? That would be awesome and preserve my turbos and gas, dont need my turbos 100% on my daily commute. But i think there would be some adaptation issues.
  3. #28
    Should work with Cobb also. I'll have to test it.
  4. #29
    Click here to enlarge Originally Posted by woodga16 Click here to enlarge
    what's the point of this map? Is it for worst case scenario, turbos fail and you have a map to get home by?
    The point is because you can.
  5. #30
    NYC
    104 Post(s)
    Sticky, check your e-mail. Apparently my 9.8 60-130 run going down a hill is only a 1.4x% slope lol Click here to enlarge Sorry for the OT.
  6. #31
    Click here to enlarge Originally Posted by themyst Click here to enlarge
    No prob, I got it. Won't update anything for a bit though, I'm way backed up since I took Sunday off for my Bday.
  7. #32
    NYC
    104 Post(s)
    pls just tell me if its a legit run Click here to enlarge The suspense is killing me and I want to know if I'm an idiot or if i calculated slope correctly...
  8. #33
    Mar 2011
    Actually after i sent a log to the COBB guys, they are now telling me that there is an issue with logging and that the JB might be interfering with something, even though i use the 10/1 firmware you sent for JB4.
    Has anyone experienced the same problem, logging COBB on map 0 (jb4), but apparently to COBB, the logs look off at some points.
    and running S2 no fmic, when i gradually floor the car in 5th gear (AT) at 3.5k to 4.5k i feel the car has no torque it like stalls and then kiks in at 5 k as if another turbo came alive.
    What the hell is wrong please adviseeeeeeeeeeeeeeee
  9. #34
    Stockholm
    61 Post(s)
    Dzenno mentioned that even on map 0 jb4 there could be som CAN issues. i have never logged with COBB with jb4 installed but from what i remember he said that RPM should be shown in cobb as channel otherwise the logging could suddenly stop working.
    Click here to enlarge Originally Posted by Bash Click here to enlarge
    Mar 2011
    i thought Terry addressed that its fixed on the 10/1 firmware. looks like i have to remove it now... thanks Enrita
  11. #36
    Stockholm
    61 Post(s)
    i am not sure , ask Dzenno , he has done tons of testing .
    www.bootmod3.com
    233 Post(s)
    I'm unable to log properly with the AP while jb4 is plugged in but I'm still on older jb4 firmware..I think Terry fixed it in a newer firmware so they cooperate better...check with him..I only log with the jb4 on this "combo"
  13. #38
    Jun 2010
    Boynton Beach, FL
    62 Post(s)
    Im pretty sure that has nothing to do with the jb4. My 6mt drove the same way on Cobb stage 2. @DBFIU walked the $#@! out of me. I thought it was just my car.
    Current: E46 M3 s366, e85, ms3pro evo, smg->manual
    Gone but not forgotten:
    -996 Turbo twin 5757’s
    -e36 M3 760whp
  14. #39
    It's possible. Although I ran around for quite some time on map 0 w/ Cobb enabled without issue. Didn't do much logging with the Cobb but did some and didn't have any issues. If others can recreate the issue I can spend more time with it. If its perfect when not logging with Cobb and acts up only when logging then that would point to some issue. Like the JB4 is resetting itself, or something, during your runs. Don't imagine it will be difficult to correct but would need more info/verification before I dive in.
  15. #40
    Re: NA mode I got it working on the N55 also! Although after a few shifts boost creeps up to 4-5psi at 0% duty cycle. Click here to enlarge
