Results 1 to 8 of 8
Thread: Meth won't stay on...
09-30-2011, 03:46 PM #1
So I'm running a jb4 with the 2.2 pro tank and my meth will kick in for a second then stop, according to the jb4. I checked the lines, and tested the pump, everything seems to work. But when I go WO, it kicks in for a second then stops...no clue what's going on. I can't log it right now, so wondering if anyone has had this problem...
ThanksBimmerBoost's Resident n00b...
Titanium Silver 2003 335 Ci || Premium Package || Sport Package || SOLD
Sapphire Metallic Black 2008 535i || Custom Mandrel Bend Borla Exhaust || BMS Spacers || CMS Pro Meth Kit || JB4 || BMS DCI || SOLD
Alpine White 2012 C63 Coupe || AMG Development Package || Multimedia Package || Lighting Package || LEASE ENDED
Alpine White 2015 M3 || Driver Assistance Plus || Executive Package || Lighting Package || M Double-clutch and Adaptive M Suspension ||
10-01-2011, 12:08 AM #2
10-01-2011, 12:54 AM #3
- Strong Island
- 3,432
- 3,063.0
- 101 Post(s)
- 31
10-01-2011, 03:28 AM #4
10-01-2011, 03:31 AM #5
If you see it stops working according to JB4, how comes you cant log?
Check all wirings. You can also force the pump to run and see if it stops after a short time. The only time I've seen this type of problem is for people that used the previous in-trunk tank and didn't install a suction hose in the tank as needed. I guess this should not be a problem with the new tank.
Are you using a CM controller and if so, how is it configured?
10-01-2011, 12:15 PM #6
I have my gauges show the meth flow and boost so I can tell when the meth kicks in.
All the wirings are good, and everything works. I checked teh tubing, and forced the pump to flow for a good 10 seconds in a row. The kit I'm using is the 2.2 gal pro tank with the FSB and JB4. No CM controller...everything is set the way it should be according to the JB4/FSB install manual. Oh also one thing I noticed is that, it drops during shifts then doesn't pick back up...it seems to stay on if I don't shift...is there a gear restriction? I thought it was controlled by RPM...BimmerBoost's Resident n00b...
10-01-2011, 12:36 PM #7
Supporting Vendor
Most likely you have some actual flow problem you'll need to troubleshoot. You could set methflowmax = 100 (which changes it from FSB input to 0-5v input so we can just see the actual voltages coming out of the FSB) and then do a couple runs on map 3. Then email in the CSV export.
10-01-2011, 05:07 PM #8
Sent...and that's why I'll be a BMS fan for life!
