7 Attachment(s)
Feeding the Addiction (Dyno Progress)
Following the short-lived stock frame WR on VTT 2+ 20T twins (LINK), I went ahead and changed setups, seeking even more power. This time I went with the Ventura Motorsports top mount kit with 6466 G2.
Setup:
- N54, FBO, 6MT (Spec 3+)
- VM single turbo kit, PTE 6466 G2
- JB4 G5, back-end flash (MHD)
- BMS Port Injection kit
- Split Second injector controller (AIC1-G4H)
- Fuel-it Stage 3 dual LPFPs
- e85
Going from stock frames, I was worried about lag, however during normal driving, it feels like a stock car in terms or part throttle torque. There are some conditions where rpms are below 3k where you need to downshift, such as going 60mph in 6th gear. Outside of this, the drivability of this kit is a non-event. Spool on the street is quick, and once it comes on it just never let's up. I don't notice lag between gears on a multi-gear pull.
The craftsmanship on the kit is top notch! I've worked with a couple kits and this one is my fav. There is literally NO room for error with kits on this car. Customer service from VM (Payam) was ridiculous. Service before the sale was far better than most give after the sale. He really helped work through any questions I had.
Anyway, I just an a quick hour on the dyno, so I loaded up some base maps and had it. At 23psi (map 4), it made 650whp. Going to 26.xpsi jump over the 700whp mark! Final numbers were 719whp @ ~26-27psi.
Attached are some pictures and data. I've plotted today's last run against my kill mode 20T twins, as well as my all-out stock turbo runs.
http://datazap.me/u/ghost/dyno-9-int...-29&solo=3-4-9
A few observations:
- I'm out of fuel at this power level, as HPFP and LPFP are diving. Fortunately, I have a Fuel-it FPR and feed/return line kit here ready to install. I hope to get this in and back on the dyno in the coming weeks.
- My PWM (WGDC) is much higher than expected at this low a boost level. Previously, a value of 25 was good for 23 psi where today it requires 45. I'll do another boost leak test and see if I find a problem.
- AFR measured at the tailpipe one the dyno reads a good 0.5 point lower than measured at the front O2. Because of that, I richened the map by 0.5 (target 11.9:1, measured 12.4:1 on the external WB) and gained 20whp throughout most of the powerband. I suspect the tailpipe sniffer is more accurate and that I was too lean before.
- I didn't spend any time on spool or timing. I'm sure the spool can be improved; I already make 20psi at 3600 rpms on the street as-is plus have BMS anti-lag installed.
- I have zero traction on the street now (PSS, LSD, lockdown, etc.) :facepalm
More to come.
