Went to local track and did a few 1/8 mile runs. 2.01 60ft @84.98 mph and 8.489. Reaction time sucked on that one, 1.105. Would have loved an 8.3--
basically stock car?
Pump gas tune? (91 I assume)
You can't log so you have no idea what boost ... really makes any advice hard to give. But, I'm auto and get pretty consistent 1.8x 60' and 7.6xx @ 98mph on the OTS E40 flash. Stock turbos and 90,000 miles on them. I am FBO though.
Best advice for an auto, 2nd gear starts.
I'll have to try that. Am I shifting at about the 60' mark? And wow, 98 mph in 1/8 mile!! Rock that shit!! I guess without shifting until about 60~ mph will negate starting in a higher gear. Still working on getting a laptop to borrow for a few days so I can do some logs. I might be able to get one next weekend.
Once you can log you'll find out optimal shift points, based on boost taper.
For me boost taper starts at 5,200 rpm. So that is close to where I shift. The cars don't make much power after that and TQ really drops off. So to be faster you have to shift earlier ... it can make a world of difference in times!
Yes, basically stock car except free flowing after cat exhaust and injen cai. 125k on car and I believe turbos. I'm getting airbag recall done soon and will get a printout of all service work done then. I've done myself, plugs, coils, oil, trans, transfer case, differentials, brake fluid, and power steering fluid. Need to do coolant flush, valve cleaning. Me and a buddy are going to tackle a single 3.5" exhaust this fall as well as install a 7.5" intercooler. I was shifting about 6,500 rpm but was actually trying for no later than 6k and 5500 is probably the better #. I'll be going back hopefully in about 2 weeks andcwill try 5500 and 2nd gear starts
I was looking at a MHD 1+ dunno and saw it was 400 at 4500rpm and 250 at 7200 so I was trying to shift it right to that 4500 mark for max tq. I'll get close to the 7s next time I go for sure. Reaction time and 2nd gear starts. And 93 octane tune
I just ran over this :) I would love to try the Pump Map on my car but i have IJE0S.
Can i copy paste (using correct XDFs) this to an IJE0S Map? Or does anybody have this as an IJE0S maybe already?
Would be awesome!!
