Originally Posted by
Flinchy
yes, and working out even if it can inject RIGHT up to combustion from TDC intake, 1 full RPM, 50% duty cycle in effect... they still can't (according to the specs) flow anywhere near enough on E85, and even on race gas it may not satisfy *everyone*.
How can DI have more time to spray?
PI can spray through all 4 strokes, DI, best case scenario, has 2 strokes to spray through.. and i'm not even sure the N54 can do all intake all compression.
at least working this out may have a semblance of reality compared to trying to work out block strength with only half the info :P
I agree, even if it's not going to be accurate (like the initial 'N54 will break apart at 500hp'), it's interesting.
The only hope i can see is the injectors being fairly underrated?.. you're right though, hopefully we'll see soon enough with your HPFP work :D
do you have a link to the thread? the only one i can find with a continental engineer was pretty basic stuff, with non-specific window stuff saying 'yeah it COULD run stratified' and saying that it only runs homogenous (which according to the flow specs is impossible at current power levels, as 4MS at 7k rpm is nowhere near enough for any fun)
with you mentioning wall-wetting, i think we're talking about the same thread maybe lol.
is that what you were remembering?
not sure how wall wetting could be an issue injecting into compression, high powered cars drink much more fuel all the time... but this doesn't really tell us anything useful, mostly vague and the performance specs are the same as can be found in the pdf >_<
