Thank You Sticky
I will send a message to ezec63 if not check very often this topic
Greetings.
P.S. Do you really have a hundred thousand posts in this forum? :o
Thank You Sticky
Greetings.
Hello thanks for the kinds words appreciate it ! The car is now running a Weistec stage 3 supercharger and the coolers have been working flawlessly since I installed them. When I get back home later tonight I will PM you the details of the installation and the contact I used to order genuine black series parts straight from Mercedes. Aslong as you have a shop in your area that does quality custom work or your willing to do it yourself it shouldn't be a problem it's not a major Job a lot of the parts bolt on and the key modification is to one of the end lines going from main black series oil cooler to auxiliary cooler I'll have details in my message. AMG has actually released a "cooling package" upgrade that involves changing to the black series cooler done at any dealership but as you would imagine it's very expensive and they only change the oil cooler not the trans cooler which is key for trans life.
Lovely car you have there. I didn't know that the Eurocharged V5 tune moved the redline up to 7800rpm?! That's awesome!!
Would have been useful if you had a dyno plot before/after the throttle bodies were fitted.
Great build. I don’t have reputation point to send PM but was hoping you can point me in the right direction with part numbers and supplier for the BS oil cooler parts.
Thank you
Thank you
