MHD moved N55 E-Series flash tuner to open beta MEVD 1726
Still need to bench flash first though right @martial@mhd?
Quote:
Originally Posted by MHD
MHD Flasher late e-series open beta announcement.After extensive closed beta testing - we are now ready for the open beta. Just update your MHD Flasher N55 App to the latest 1.20 version.
Since the procedure on late e-series cars (built after 03/2012) is a little bit different, we would like to describe the steps needed:
1. OBD Unlock via a one time bench flash. This can be done only by professional partners which have access to special tuner tools. Ask your local tuner and we can provide them all the information they need in order to get your ECU unlocked. You can also send your ECU to our partners - if you are able to uninstall it yourself.
2. Install MHD like on early e-series N55 and N54 models. Just be careful with the "flash back to stock" operation. If you use this function than your ECU unlock is deleted and MHD can only be installed after the ECU is unlocked again. If you want stock power than use the "Stage 0" map.
Send us a PM if you have questions!
