Fuel-It STG3 Hobbs Switch Question (mounting location)
Hey guys,
This is a dumb question; more just curious regarding best practice. I have the hobbs switch for the secondary lpfp pump; previously I had been using the JB to trigger it and then borrowed a friends chargepipe with 'normal' taps for meth bungs.
However - my actual chargepipe is tapped for an aquamist bung; the ID is smaller than that of the Hobbs switch.
Anyone mounted the switch elsewhere? I was thinking about just adding in another T to the boost reference coming off the manifold...But since it's already T'd once (BOV and AEM Boost Gauge), would that be over doing it? I haven't drilled out the manifold for an NPT fitting so it's the stock diameter.
Alternatively, I could drill tap the charge pipe to fit the larger thread size of the hobbs switch.
Thoughts? Preferences? Just need to find a good boost reference.
