Cobb and Procede Stack - Bank 2 running extremely lean with flatlined fuel trims
Hi,
I'm wondering if someone would be able to help me out with this issue. I recently had RB turbos installed and I had the mechanic change both pre-cat O2 sensors due to an issue I was having where my bank 2 AFRs are richer by about 1 point throughout the rev range and also at idle. Fuel trims for bank 2 are also higher indicating that although the AFRs are richer than the target it's also trying to add more fuel which doesn't seem to make sense. It's not a methanol thing since this happens at idle and also before meth sprays.
This is an example of the issue I was experiencing.
http://www.datazap.me/u/froop/201406...a=1-5-7-8-9-10
I recently changed to a Cobb and Procede stack and however today, I noticed that when datalogging I was running extremely lean in bank 2 and my fuel trims for bank 2 were flat lined and pegged at 0. This is the datalog.
http://www.datazap.me/u/froop/201407...a=1-5-7-8-9-10
If I turned off the engine and turned it back on again the AFRs would go back to "normal" (richer bank 2). On the way home though I kept getting this issue with normal driving and I had to pull over a few times to turn on/off the engine. I threw a CEL even with CANClear on and the following codes showed up when driving back home.
2C32 - Lambda probe in front of cataytic converter 2, trimming control
2C2C - Lambda probe in front of cataytic converter 2, system check
2C6C - Lambda probe behind catalytic converter 2, system check
Now the richer AFRs don't seem to be tune related since I've been having them with just the Procede, just the Cobb and with the Cobb and Procede stacked. I've had the front (pre-cat) O2 sensors replaced (as far as I know). Is it possible that a faulty rear (post-cat) O2 sensor is to blame?
Btw, here are a couple logs that I took today when the car wasn't running lean in bank 2. Car hauls ass :D. I've still yet to raise the boost and timing a little but I need to get this AFR/Fuel trim issue sorted.
http://www.datazap.me/u/froop/201407...7-8-9-10-11-12
Thanks,
Alex
