2C32 and 2C6C Error Codes - Bad O2(s)?
So my car has not been running right and when I went to datalog it, it appears to confirm the issue. Summary: No timing and car studders on partial throttle. Bad o2 sensor, both or upstream causing bad readings?
Car: 2009 335i, FBO + AE Exhaust running procede rev 3 with backend fuel flash.
So I have the two error codes listed in the subject. I also have the misfire and voltage supply error, but searched and found that is 2-step and NLS. I turned off the procede, map 0, as well as reload default maps and the problem persists. Guessing it is a sensor. Below is the log, but AFR's and fuel trims are not matching as well as I am dropping a lot of timing, which I am guessing is the engine protecting itself. Given the 2C32 is a trimming error and the other is a system check, the logs at least confirm this.
I have also noticed on occasion (rare, only if I leave my car on and still only occasionally) white smoke coming from the passenger exhaust. Anyone provide some feedback?
Not enough rep for a link.
datazap.me/u/am3ricus/lamda-sensor
