E30 FBO map ok for stock car w/E50?
Could the Cobb E30 map be used with an unmodified stock car and E50? I saw the logs, and there were no ignition corrections in those few logs that I saw. I believe the fuel scalar should be adjusted up though to be on the safe side not maxing the trims. I told him to pick the scalar from the Cobb scalar table.
Anything else that would need to be taken into account and should be adjusted in the map? For example, anything related to keeping the stock cats alive? I guess the Cobb E30 map would be the best starting point for him running stock car w/ E50 and make minor adjustments to it if needed?
