Single turbo tuning help...
Hey guys,
So...the good news...car is up and running! Actually picked it up Tuesday, but ended up finding out later that night the spring put in was a bit too stiff, honest mistake, too stiff of a spring installed. Went back today and put a 1 bar spring combo in. So wastegate spring should be ~13psi.
I have somewhere around an e35 fuel mixture. Running a 255 inline pump. Turbo is a Forced Performance HTA3586r (62.5mm single scroll)
I did a map4 pull and here are the results. NO codes were thrown but something is definitely off...
http://datazap.me/u/mjmarovi/map4-13...g=0&data=1-3-4
Then....decided car was at least good to drive home (shop is ~1 hour away) so hit the highway. It was really strange, I heard almost an odd noise, hard to describe, but kinda like a low hummm. Service engine light came on, brake light came on, and by the time I started pulling over it was as if the fuel cut out and then the engine completely shut off. All lights, navigation screen, etc. were on as normal. Took a picture of all the codes, check under the hood for anything disconnected, melted, etc. All was good so cleared the codes. Car started up just fine and drove home about another 20 miles or so home no issues. Here's the codes...thoughts?
Also, what all maps is METH suppose to flow with single turbo firmware? I take it map4 is NOT one of them?
https://mail.google.com/mail/u/0/?ui...&sz=w1254-h496
