Warnings to 335is owners and possible others?
Little back ground. I have a 2011 335is manual with 20k miles. Modifications include cobb flash, FMIC, DPs, Intake, and RB upgraded turbos. Everything was on the car when I brought it to the dealer but the cobb, I had uninstalled it.
So, I had my brake pad service indicator on for a month or so, with the miles indicator counting down. Took it in about 3 weeks ago and they noted that the pads were fine (60%) but that the system was off and needed to be updated. I said okay, no worries. Get it back the next day.
I have been swamped with work and didn’t have a chance to put the cobb back on. One thing odd I noted was I wasn’t getting an error for not having my primary cats and I wasn’t see fuel pump codes (running e45 with a stock fueling system with RBs was taking its toll) like I was before bringing it in.
So, last week I had time to install the cobb and get Rom not recognized. I fired off to Cobb and received the following info from cobb.
I received your rom and have started to get working on it, but this is a completely new family of roms that I have never seen. Is this your first time attempting to install the Accessport, or did you recently get an update from the dealer? Just curious...
At any rate, this is going to be a very slow process as I work through it. It seems BMW has made some significant changes and it will take me quite a while to get everything sorted.
I am following up and he noted weeks to months to update. As I have a ½ event in 2 months, that event might be pretty boring if I am stuck at 350 hp.
Anyway, be weary if they ask to reflash your car if you are on cobb.
Cheers,
James
