Playing with the LPFP side of things....
Thought I'd post up some stuff for you guys...
Got a new toy today for testing. An adjustable 12-15V 35 amp power supply :music-rockout:
Here are a few vids although not very good ones...I'll work on that :facepalm
In all of these the voltage is a DVM verified 13.5 and I set the pressure to 75psi. Also...none of them have a modified venturi...in all of them the venturi is completely stock and in place....no hose clamps...no lines leading to the venturi...STOCK! :naughty:
Stock LPFP (I said 9amp...but it was 12amps)
http://youtu.be/7ipzeC7btxo
Same stock LPFP with 255 inline
http://youtu.be/bECx9OVNrCo
New upgraded bucket ( A complete drop in and go setup)
http://youtu.be/h7QtDUUeK8U
New upgraded bucket and 255 inline
http://youtu.be/HmXYweNU4bM
In that last test I believe I have maxed out my test rigs capacity since I'm only using 1/4" lines to the pressure control valve. I turned the pressure up to 100 psi and it still flowed 1.125GPM...usually you'd see the flows drop.
Also, that last test has not been road tested yet...it will be going in my car along with a 25amp fuse. For most people I suspect it'll be overkill and could cause problems unless their fuel system is setup for it or they're able to make use of the capacity (HPFP...E85...or whatever). We'll see but my car won't really validate that as it doesn't have a stock fuel system.
